[QGIS-Developer] Current state of QtWebKit dependency
Tom Elwertowski
telwertowski at comcast.net
Thu Jun 27 17:23:08 PDT 2019
QtWebKit 5.9.0 builds with Qt 5.13.0 on macOS 10.14.
Using Qt 5.12, the QMAKE_INCDIR_OPENGL path in
clang_64/mkspecs/modules/qt_lib_gui_private.pri needs to be fixed. Qt
5.11 and earlier are ok.
The latest QScintilla and PyQt5 also compile ok with Qt 5.13.0 and macOS
10.14.
Tom
On 6/27/19 7:20 PM, Nyall Dawson wrote:
> On Fri, 28 Jun 2019 at 05:27, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> What's the current state of QtWebKit dependency within the main source code?
>> I have seen this post and am curious if it is still true:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-qgis2web-and-qtwebkit-tp5378226p5378445.html
> Nothing's changed on either side, unfortunately. We still NEED
> qtwebkit, and the situation upstream is still a confusing pile of
> excrement and misinformation.
>> I'm assuming that if there is still a dependency on QtWebKit there is also a need for the PyQt bindings for its modules as well.
> Yes. You can build without it, but that's really just a hack to allow
> a build to proceed. The resulting QGIS app will be crippled and
> missing core functionality.
> Nyall
>> Regards,
>> Larry Shaffer
>> Dakota Cartography
>> Black Hills, South Dakota
