[QGIS-Developer] QGIS 3.8 Transformations dialog
Richard Duivenvoorde
rdmailings at duif.net
Fri Jun 28 00:11:22 PDT 2019
On 28/06/2019 01.28, Nyall Dawson wrote:
>> That one shows 'just' 2 options (added to the qgis.nl post)
>> IF the green line is just the first one, but we are not sure if it is
>> the right one... should we make it green anyway?
> Ah, on proj 6 builds, we ARE sure that the first/green one is the most
> recommended one :) That's because proj gives us an ordered list of
> possible operations in order of preference (calculated using all
> proj's internal smarts and knowledge about the accuracy of different
> transform operations).
Mmm, then my last question, after this I'll move to proj ;-)
See:
http://www.qgis.nl/media/2019/06/Screenshot-20190627104509-716x467.png
This is QGIS with proj6: As you see there are 2 options. The first one
being green 'numbered' (3). But the bottom one having a higher number
between brackets having a (4) between brackets?
Now /me wondering what these numbers are: because given your answer
above, the green one being 'THE one' :-) I wonder what this other
numbers are (I was wondering ordered by date/relevance or so)??
Regards,
