[QGIS-Developer] Sunrise, Sunset, Lunar Calculations
C Hamilton
adenaculture at gmail.com
Fri Jun 28 06:13:31 PDT 2019
Thank you for all the comments. To summarize.
1. Having this capability would be useful.
2. Take a look at pvlib.
3. Add it to expression functions and possibly add it as a core C++
function.
4. Take a look at GRASS r.sun and related commands.
5. Take a look at the astral library.
6. Take a look at GEarthView
My philosophy is that QGIS is a professional GIS application and as such
its algorithms used need to be the most accurate that are available. The
Sun and Lunar algorithms are not trivial and I would want to use an
existing library. I know there are some simplified approximation algorithms
that you find used on the web particularly in JavaScript mapping
applications. I would prefer the more accurate algorithms, but will be
limited somewhat with what I can easily include.
If this capability were to be added as core C functions, then I think you
would need to link it to one of the astronomical libraries. I think all of
the python libraries are probably in part derived from the C libraries. Is
adding an astronomical library to QGIS of interest? I don't think we should
use the simplified algorithms. I have not looked into C libraries, but I
know that the author of Skyfield (formerly PyEphem which is now deprecated)
based his code on the US Naval Observatory NOVAS library. I can see that
having astronomical calculations in QGIS would be beneficial to some and
could even open it up to other uses, but I don't know how much you would be
interested in making these core functions, but lets start the discussion as
it might affect my approach.
I have already been looking at possibly using one of the python libraries:
astral, skyfield, astroplan, and astropy. I know some in the community
disagree with including libraries with the plugin, but in my experience
most of my users do not have root privileges and if the plugin requires the
extra step of having system administrators pip install additional packages
then it eliminates most users from being able to use the plugin. (Part of
this is due to laziness.) So if I do this I will include the libraries with
the plugin unless the QGIS community decides they would like to support
astronomical calculations as a part of core QGIS.
Calvin
On Fri, Jun 28, 2019 at 3:52 AM Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Calvin
> On Thu, Jun 27, 2019 at 9:15 PM C Hamilton <adenaculture at gmail.com> wrote:
> > How much interested would there be for a plugin to display sunrise and
> sunset information for a particular location on the earth's surface. Is
> anyone already working on this? There doesn't seem to be a capability for
> this, but perhaps I have missed it. Are there other astronomical
> calculations that would be worth while in QGIS? (Moon asimuth/position,
> phase)
> Just adding another +1 vote to have something like this in QGIS :-) At
> some point I would like to look into rendering of shadows of buildings
> in QGIS 3D - and for this it would be important to have the ability to
> calculate sun position.
> Cheers
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190628/b74c9273/attachment.html>
