[QGIS-Developer] Save layer metadata to global datasource
Gerald Kogler
geraldo at servus.at
Fri Jun 28 08:30:56 PDT 2019
Hi ppl,
Layer metadata currently is saved either as a .qmd file on disk or as a
record in the users personal "qgis.qmldb" (tbl_metadata).
We now have the problem that metadata gets lost when using a Postgis
layer by a different user/user profile. So we miss the option to save
the metadata together with the layer.
I imagine a solution similar to styles, where you choose between Local
Database or Datasource Database when "Save as Default".
So in Postgres we would need a additional table "public.layer_metadata"
with column "metadata" to save the URI (text) and column "qmd" to save
the XML.
Any thoughts on that, would that make sense?
thanks
Gerald
