[QGIS-Developer] GSoC QGIS 3D Improvement: Week 4 Report
Ismail Sunni imajimatika at gmail.com
Sun Jun 30 14:12:54 PDT 2019
Hi Tim,
Sorry, I missed this email from you.
Thanks for the update Sunni! Do measurements happen in 3d too? For example
> if you measure to the top of a building do you get a different measurement
> compared to the base?
Yes, the measurements happen in 3D. You can measure the building height now
> Maybe you could show the Z elevation change at each measurement row and
> the total elevation change  in the total box?
Hmm, that's a good idea. I will keep it on my list, and I will try to
implement it after the other 2 features finished. Thanks!
Hope you are feeling better now!
Thanks, I am feeling better indeed now :)
Best regards
> compared to the base? Maybe you could show the Z elevation change at each
> measurement row and the total elevation change  in the total box?
> Regards
> Tim
> On 23 Jun 2019, at 15:29, Ismail Sunni <imajimatika at gmail.com> wrote:
> Dear QGIS developers,
> Here is my 3rd-week report for my GSoC Project. You can read this report
> better with image and GIF in the weekly report wiki [6]. You can also check
> the project wiki page [3]. Comments and suggestions are welcome :)
> GSoC QGIS 3D Improvement Week 4 Report
> *Period*: 17 June 2019 - 23 June 2019
> *Report*
> 1. What did I complete this week?
>    - Replicate UI from 2D measurement tool to the 3D measurement tool
> dialog.
>      Almost all functionalities are replicated, except:
>      - Show help (the behavior is added, but since there is no chapter for
> it currently. It's disabled for now)
>      - Configuration (already started working on it, but time is quite
> limited last week since I feel a little bit unwell last week)
>      List of implemented behaviors can be found in [4]. You can see it on
> a GIF [5].
>      ![3D Measurement Tool with Dialog](
> https://user-images.githubusercontent.com/1421861/59976840-2a78c100-95ca-11e9-9e32-16b6c34b4ce9.gif
>    - Adding map tool for camera control in 3D view (similar to the Pan
> tool in 2D view) to make it more consistent and easier to see what's the
> active tool.
>    - Change the cursor for 3D identify tool for consistency with 2D one.
>    - Adding missing `QgsDistanceArea::MeasureLine3D` for `QgsPoint`, unit
> test is added.
>    - Trying to fix the rendering issue, but still no luck.
> 2. What am I going to achieve for next week?
>    - Finish the configuration
>    - Try again with the rendering issue
>    - Wrap up PR if the all is finished (currently a draft)
>    - Some testing
>    - Start working on the 3rd feature, point as a billboard.
> 3. Is there any blocking issue?
>    - Yes, the line is rendered but the color is random and rendered as 2D.
> The line will be gone if I hide/show another line [2].
>      ![Rendering Problem](
> https://user-images.githubusercontent.com/1421861/59567331-c22b5c00-906c-11e9-808f-0a7e93e8f54a.png
> 4. Code
>    - Branch in my repo [1]
> 5. Misc
>    - N/A
> *References*
> - [1] https://github.com/ismailsunni/QGIS/tree/measurement-tool
> - [2] https://github.com/ismailsunni/QGIS/issues/2#issuecomment-502470762
> - [3] Project Wiki:
> https://github.com/ismailsunni/QGIS/wiki/GSoC-2019---QGIS-3D-Improvement
> - [4] https://github.com/ismailsunni/QGIS/issues/2#issuecomment-504750318
> - [5]
> - [6] https://github.com/ismailsunni/QGIS/wiki/Week-4-Report
> Best regards
> Ismail Sunni
> ismailsunni.wordpress.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> *Tim Sutton*
> *Co-founder:* Kartoza
> *Ex Project chair:* QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:* timlinux on #qgis at freenode.net
> I'd love to connect. Here's my calendar link
> <https://calendly.com/timlinux> to make finding time easy.
Ismail Sunni
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190630/b8413171/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190630/b8413171/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
