[QGIS-Developer] Projects without a CRS
Harrissou delazj at gmail.com
Sun Jun 30 23:59:01 PDT 2019
Hi Andreas
I think there are some (partial?) answers in docs, in case you didn't read it yet.
https://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_configuration.html#crs-properties
Regards,
Harrissou
Le 1 juillet 2019 08:46:03 GMT+02:00, Andreas Neumann <a.neumann at carto.net> a écrit :
>Hi,
>I am wondering about projects without a CRS. While a new project now
>always comes with a CRS (depending on the global CRS settings), the
>user
>can still explicitly disable a definition of a CRS in Menu "Project"
>"Properties" --> "CRS"
>I have the following questions about projects without a CRS:
>- what are the restrictions/limitations of projects without a CRS?
>- assuming that a layer has a CRS (e.g. a Postgis layer that has a CRS)
>is loaded into a project that explictly has no CRS set - does QGIS
>still
>know the CRS of the Postgis layer or would it treat it as a CRS-less
>layer?
>- does it still make sense to support projects without a CRS? If yes,
>what are the use cases?
>- will it still be possible to have projects without a CRS or will this
>one day be deprecated
>I personally do understand that it is not a good idea to have projects
>with no CRS defined, but I am trying to understand and convince my
>colleagues at my workplace that projects without a CRS are an absolute
>nogo. But maybe I am wrong and it still makes sense to support projects
>without a CRS.
>One use case I could think of for projects without a CRS, is using QGIS
>for something that is planar, but not geographic in nature, e.g. a
>non-GIS topic, such as examining an image (let's say the enlarged view
>of an electron microscope of some small thing) where the user might
>want
>to "map" certain characteristics of the image, but the object itself is
>"mobile" (can move around) and is not fixed to a fixed position of the
>earth.
>What are your thoughts about projects without a CRS?
>Greetings,
>Andreas
Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser ma brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190701/9692ef5b/attachment.html>
More information about the QGIS-Developer mailing list
