[QGIS-Developer] PyQGIS docs / plugins and use of Constant and Enumerations
Richard Duivenvoorde
rdmailings at duif.net
Fri Mar 1 08:47:47 PST 2019
Hi Devs,
a plugin dev was discussing with me the fact he could not find the names
of the different Enumeration values in QGIS to use for python plugins.
As an example: if you want to test if your layers 'type':
iface.mapCanvas().currentLayer().type()
0
is a Vector layer, so you could go to:
https://qgis.org/api/classQgsMapLayer.html#adf3b0b576d7812c4359ece2142170308
Then to the maplayer.h file:
https://qgis.org/api/qgsmaplayer_8h_source.html#l00106
>From where you can count that Vector = 1 etc...
and guess to use:
QgsMapLayer.VectorLayer
Another example: having a 2.x plugin with a test:
geom_type == QGis.WKBPolygon
=> 3
I found:
https://qgis.org/api/classQgsWkbTypes.html#a60e72c2f73cb07fdbcdbc2d5068b5d9c
and then:
https://qgis.org/api/qgswkbtypes_8h_source.html
BUT how can we make this easier for python devs?
Searching in https://qgis.org/pyqgis for example VectorLayer the
constant (as name) does not pop up.
So what would work:
- add comments in the header files? Would these show up in the python
docs then?
- create (automated?) lists of these constants in the pycookbook?
- do a lot of blogging about it :-)
Or: who has an idea (so somebody can maybe pick this up in A Coruna....
Regards,
