[QGIS-Developer] QgsProcessingParameterMatrix - numberRows is not respected in the UI
Nyall Dawson nyall.dawson at gmail.com
Fri Mar 1 15:38:14 PST 2019
On Sat, 2 Mar 2019 at 00:11, René-Luc Dhont <rldhont at gmail.com> wrote:
> Hi Devs,
> I'd like to use QgsProcessingParameterMatrix with fixed rows number,
> like it's defined in SAGA User defined filter algorithm.
> And like in SAGA User defined filter algorithm, the table displayed has
> no rows.
> Which part of the QGIS code has to build the displayed table ?
https://github.com/qgis/QGIS/blob/master/src/gui/processing/qgsprocessingmatrixparameterdialog.cpp#L111
with unit tests here:
https://github.com/qgis/QGIS/blob/master/tests/src/gui/testprocessinggui.cpp#L1760
Let me know if you have any questions about this code -- it's only
new, so is fresh on my mind.
Nyall
> Thanks,
> René-Luc
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
