[QGIS-Developer] QgsProcessingParameterMatrix - numberRows is not respected in the UI
Nyall Dawson nyall.dawson at gmail.com
Mon Mar 4 14:53:49 PST 2019
On Mon, 4 Mar 2019 at 21:20, René-Luc Dhont <rldhont at gmail.com> wrote:
> Hi Nyall,
> Thanks for the answer.
> To work around the issue, I have to provide a default value.
> In the case of a QgsProcessingParameterMatrix with fixed rows number has
> a default value have to be provided by the definition or the class ?
What about just creating an empty table with the required number of
rows in QgsProcessingMatrixParameterDialog::populateTable whenever
mParam has a fixed number of rows set?
Nyall
> René-Luc
> Le 02/03/2019 à 00:38, Nyall Dawson a écrit :
> > On Sat, 2 Mar 2019 at 00:11, René-Luc Dhont <rldhont at gmail.com> wrote:
> >> Hi Devs,
> >> I'd like to use QgsProcessingParameterMatrix with fixed rows number,
> >> like it's defined in SAGA User defined filter algorithm.
> >> And like in SAGA User defined filter algorithm, the table displayed has
> >> no rows.
> >> Which part of the QGIS code has to build the displayed table ?
> > https://github.com/qgis/QGIS/blob/master/src/gui/processing/qgsprocessingmatrixparameterdialog.cpp#L111
> > with unit tests here:
> > https://github.com/qgis/QGIS/blob/master/tests/src/gui/testprocessinggui.cpp#L1760
> > Let me know if you have any questions about this code -- it's only
> > new, so is fresh on my mind.
> > Nyall
> >> Thanks,
> >> René-Luc
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
