[QGIS-Developer] [Qgis-user] QGIS package broken on Ubuntu Bionic with UbuntuGIS PPA
Alex M
tech_dev at wildintellect.com
Mon Mar 4 14:56:59 PST 2019
Thanks for the report, I'm forwarding to the Ubuntugis list and QGIS
Developers list, the 2 groups that manage these things.
I believe I have this combo working on a machine, will need to check.
Looking at the repos, I see new version of packages went up 10 hours
ago. It is possible the QGIS release on qgis.org ubuntugis repo needs to
be rebuilt against these new packages, which usually happens within 24
hours.
Thanks,
Alex
On 3/4/19 14:39, César Augusto Ramírez Franco wrote:
> Hello,
> I don't know if this is the right place to ask this, so apologies if it
> isn't.
> Today I updated my system through apt and the gdal package got upgraded to
> 2.4.0 and at the same time the qgis package got removed.
> I'm using the ubuntugis-unstable PPA and the QGIS repo for ubuntugis:
> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu bionic
> main # ubuntugis
> deb https://qgis.org/ubuntugis bionic main # QGIS
> When I try to install QGIS again, apt complains of unmet dependencies:
> # apt install qgis
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
> qgis : Depends: gdal-abi-2-3-0 but it is not installable
> Depends: libqgis-analysis3.6.0 but it is not going to be installed
> Depends: libqgis-app3.6.0 but it is not going to be installed
> Depends: python-qgis (= 1:3.6.0+28bionic-ubuntugis) but it is not
> Recommends: qgis-plugin-grass but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> I read online that removing ubuntugis and installig from the ubuntu repo
> would solve the problem but I'm relying on some ubuntugis package versions,
> so what's the recommended solution? Shouldn't QGIS 3.6 be able to run with
> GDAL 2.4.0?
> Thanks in advance
> Qgis-user mailing list
