[QGIS-Developer] Flaky tests and Travis
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Mar 11 14:59:19 PDT 2019
I am also in favor of disabling them but maybe keep them running and have
them as expected failure?
If ones write some code related to the corresponding tests , they might
still provide some valuable info.
Is this possible?
If not I'd still be in favor of disabling them.
Cheers
Denis
On Mon, 11 Mar 2019, 22:47 Nyall Dawson, <nyall.dawson at gmail.com> wrote:
> Hi all,
> For a long time now we've been plagued by intermittently failing tests
> on Travis, which are making the whole QGIS development experience
> quite painful.
> I propose that we take an absolute hard line approach from now and
> disable all tests which are causing false positive failures. I've
> started here: https://github.com/qgis/QGIS/pull/9483
> This is obviously not ideal, as the failures may be revealing real
> bugs (and in the case of the two disabled above I believe they are
> symptoms of the same underlying bug), but I think now we've passed the
> point where leaving these tests enabled causes more damage then
> skipping them.
> Ideally someone would investigate these and fix either the tests or
> the underlying bugs... but it hasn't happened in 6+ months, so I don't
> expect that to happen shortly**. I did spend some time around a month
> ago to see if the fix for these two was trivial, but could not find it
> quickly.
> Is anyone opposed to a hard-line "disable if flaky" stance?
> Nyall
> ** For full disclosure: next round of QGIS grants I plan on filing for
> a grant to investigate all tests disabled on Travis in depth and
> either fix underlying bugs or make the tests more stable. But that's
> grant dependant, and not a short term solution.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Denis Rouzaud
denis at opengis.ch <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190311/439f9953/attachment.html>
