[QGIS-Developer] Raster Calculator troubles in Processing with pyqgis
Nyall Dawson
nyall.dawson at gmail.com
Tue Mar 12 00:17:44 PDT 2019
On Tue, 12 Mar 2019 at 17:13, matteo <matteo.ghetta at gmail.com> wrote:
> Hi devs,
> I'm facing a really strange bug (IMHO). Same script, same project, same
> data, same QGIS version (3.6), but different platform (linux vs windows).
> The EXPRESSION parameter is giving errors when used, ONLY in Windows.
> This is the small snippet I'm using without any problem in Linux:
> param_calculated = {
> 'EXPRESSION':'{}@1 * {}'.format(proximity['OUTPUT'], formula),
> 'LAYERS': proximity['OUTPUT'],
> 'OUTPUT': os.path.join(output, 'calcolato.tif')
> calculated = processing.run("qgis:rastercalculator", param_calculated)
> The exact same script is giving an error in Windows (not verbose error,
> just saying processing.run is not running).
> I discovered that, if I load the raster(s) into the TOC and user
> my_raster.name() instead of the complete path (proximity['OUTPUT']) then
> it seems working.
> Is this a known bug/problem?
Does either of the platforms have OpenCL support enabled?
Nyall
