[QGIS-Developer] Flaky tests and Travis
    Alessandro Pasotti
    apasotti at gmail.com
    Tue Mar 12 02:42:34 PDT 2019
I understand we haven't much of a choice: +1 for disabling.
I wonder if there is a way to make it more evident for developers that they
need to run disabled tests locally by hand before making a PR.
It happened to me once or twice that I made a change that I knew was
covered by a test case, let travis run, all green, merge!
And then I discovered that the test I was relying on wasn't running on
Travis and that there was a test failure when running the test locally.
On Tue, Mar 12, 2019 at 9:28 AM Matthias Kuhn <matthias at opengis.ch> wrote:
> On 3/12/19 12:28 AM, Nyall Dawson wrote:
> On Tue, 12 Mar 2019 at 07:59, Denis Rouzaud <denis.rouzaud at gmail.com> <denis.rouzaud at gmail.com> wrote:
> I am also in favor of disabling them but maybe keep them running and have them as expected failure?
> That sounds preferable -- but I'm not (personally) sure if it's
> possible. You know the CI setup better than I do, can you see a way to
> do this?
> I'm not sure this works.
> Expected failure "expects" the tests to fail and will error if it
> succeeds, since we are dealing with flaky tests here, that will still lead
> to unstable behavior.
> If not I'd still be in favor of disabling them.
> I honestly believe the harm in leaving these enabled (short term) is
> outweighing the risk of disabling them. We are very likely pushing new
> contributors away from our project with the current difficulties just
> getting a PR to green.
> I agree with the proposal, these tests do more harm than good currently.
> Matthias
> Nyall
> Cheers
> Denis
> On Mon, 11 Mar 2019, 22:47 Nyall Dawson, <nyall.dawson at gmail.com> <nyall.dawson at gmail.com> wrote:
> Hi all,
> For a long time now we've been plagued by intermittently failing tests
> on Travis, which are making the whole QGIS development experience
> quite painful.
> I propose that we take an absolute hard line approach from now and
> disable all tests which are causing false positive failures. I've
> started here: https://github.com/qgis/QGIS/pull/9483
> This is obviously not ideal, as the failures may be revealing real
> bugs (and in the case of the two disabled above I believe they are
> symptoms of the same underlying bug), but I think now we've passed the
> point where leaving these tests enabled causes more damage then
> skipping them.
> Ideally someone would investigate these and fix either the tests or
> the underlying bugs... but it hasn't happened in 6+ months, so I don't
> expect that to happen shortly**. I did spend some time around a month
> ago to see if the fix for these two was trivial, but could not find it
> quickly.
> Is anyone opposed to a hard-line "disable if flaky" stance?
> Nyall
> ** For full disclosure: next round of QGIS grants I plan on filing for
> a grant to investigate all tests disabled on Travis in depth and
> either fix underlying bugs or make the tests more stable. But that's
> grant dependant, and not a short term solution.
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Denis Rouzauddenis at opengis.ch
> +41 76 370 21 22
> Matthias Kuhn
> +41 (0)76 435 67 63 <+41764356763>
> [image: OPENGIS.ch Logo] <http://www.opengis.ch>
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190312/bc2cce73/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190312/bc2cce73/attachment-0001.png>
