[QGIS-Developer] QGIS plugin qgisMinimumVersion
Borys Jurgiel
lists at borysjurgiel.pl
Tue Mar 12 05:26:46 PDT 2019
I'm afraid IMHO it's more a long-standing behavior consistent with the
repository: the compatibility range limits are x.y. Moreover, it could be
considered an API break for private repositories that parse that version
number - and we're talking about the LTR version :/
Although I'm not sure if it's documented anywhere. If not, it could be the
only argument...
In any case, it won't be effective unless changed in the repository as well,
what is beyond my scope.
Borys
Dnia wtorek, 12 marca 2019 13:04:18 CET Havard Tveite pisze:
> Could this be regarded as a bug in the plugin manager?
> In that case it should be OK to fix it in a point release.
> Håvard
> On 11.03.2019 14:31, Borys Jurgiel wrote:
> > The reason the plugin manager sends just "?qgis=3.4" was because the point
> > releases ("micro" versions) are expected to only provide bugfixes and not
> > new features. After some thinking, I guess this approach is wrong and a
> > bug is also a reason to prevent the plugin from installing. It's easy to
> > change it in master, I'm not sure if it we should do it in a point
> > release of the LTR...
> > Another place to change would be the repository, as it also cuts off the
> > point release part. For example, the OpenLayers Plugin has
> > minimumQgisVersion=3.0.1 and is visible here:
> > http://plugins.qgis.org/plugins/plugins.xml?qgis=3.1
> > but not here:
> > http://plugins.qgis.org/plugins/plugins.xml?qgis=3.0.2
> > Regards,
> > Borys
> > Dnia poniedziałek, 11 marca 2019 13:02:19 CET Havard Tveite pisze:
> >> I just experienced a problem with a plugin.
> >> The plugin uses the optional "is_child_algorithm" parameter of
> >> the processing.run function. That parameter was introduced in
> >> 3.4.5 (LTR).
> >> I therefore set "qgisMinimumVersion=3.4.5" in the plugin's
> >> metadata.txt.
> >> It turned out that this caused the plugin not to be available for
> >> the current LTR, probably because "Parameters" is set to
> >> "?qgis=3.4" in the Plugin manager in 3.4.5.
> >> Changing to "qgisMinimumVersion=3.4", makes the plugin show in
> >> the plugin manager, but that also makes it available in 3.4.4
> >> and earlier 3.4 versions (where it will fail with an unexpected
> >> keyword argument for processing.run...).
> >> Could "micro" version be included in the Plugin manager
> >> "Parameters", or is this something that will have to be handled
> >> in the plugin code?
> >> Håvard
