[QGIS-Developer] QGIS-Developer Digest, Vol 161, Issue 49
Marco Barbieri
marcobarbieri at webmapp.it
Thu Mar 14 05:07:55 PDT 2019
Hi René-Luc,
> Which QGIS Server version ?
1:3.4.4+14stretch
> Are the XYZ services HTTPS ?
WebMapp_Tiles is a HTTPS service.
> Do you have a proxy for the server ?
No proxy on either servers.
> Can you made some curl request on the server and access a tile ?
Yes:
curl https://api.webmapp.it/tiles/11/1082/741.png --output 741.png
Merci.
Le 14/03/2019 à 10:46, Marco Barbieri a écrit :
> > I have a project in QGIS desktop with 3 XYZ Tiles base maps.
> > Everything works fine.
> > I use the same .qgs project on QGIS server and only one base map works
> > with GetMap request.
> > The following are my requests to the server. The first request shows
> > OpenStreetMap base map:
> http://qgs.webmapp.it/cgi-bin/test/qgis_mapserv.fcgi?MAP=/usr/lib/cgi-bin/test/xyz_tiles.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=1174461,5729736,1175761,5731386&CRS=EPSG:3857&WIDTH=491&HEIGHT=624&LAYERS=OpenStreetMap&FORMAT=image/png
> > This request should show the "WebMapp_Tiles" base map, but doesn't
> > work (white background):
> http://qgs.webmapp.it/cgi-bin/test/qgis_mapserv.fcgi?MAP=/usr/lib/cgi-bin/test/xyz_tiles.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=1174461,5729736,1175761,5731386&CRS=EPSG:3857&WIDTH=491&HEIGHT=624&LAYERS=WebMapp_Tiles&FORMAT=image/png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190314/9ba5e276/attachment.html>
