[QGIS-Developer] cannot import processing algorithm in 3.6
Nyall Dawson nyall.dawson at gmail.com
Wed Mar 20 19:39:24 PDT 2019
On Thu, 21 Mar 2019 at 12:17, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> Hi Nyall, thanks for your answer.
> Somewhere in the middle of a calculation process (not an algorithm) I'd
> like to add a polygon feature to a line layer. I'm using the function to
> turn the polygon into a line geometry.
> I'm using it like this and don't know I figured this out or decided on it:
> from processing.algs.qgis import PolygonsToLines
> toLines = PolygonsToLines.PolygonsToLines().convertToLines
> then later on many places in my code:
> geom = toLines(geom)
> I remember it took me a while to figure out that second line, but having
> my own short "alias" function toLines() is very convenient. But maybe I
> can create it in another way, holding the processing.run code.
I'd replace this with:
    def toLines(geom):
        return QgsGeometry(geom.get().boundary())
(Using https://qgis.org/pyqgis/master/core/QgsAbstractGeometry.html#qgis.core.QgsAbstractGeometry.boundary
Nyall
> I will try tomorrow.
> One last question, it seems to me like the old code is working again in
> 3.7. Can you confirm that?
Shouldn't be -- maybe you have a leftover .py file here?
> Kind regards,
> Raymond
> On 21-03-19 01:34, Nyall Dawson wrote:
> > On Thu, 21 Mar 2019 at 02:40, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> >> The folowing line works for me in 3.4.3 and 3.7 (built today) but not in
> >> 3.6.0
> > It was ported from Python -> c++, so is no longer importable like
> > this. What's your use case for importing direct rather than running
> > via processing.run?
> > Nyall
> Terglobo
> Fahrenheitstraat 1
> 5223 BJ 's-Hertogenbosch
> The Netherlands
> +31 (0) 6 25 31 49 83
More information about the QGIS-Developer mailing list
