[QGIS-Developer] Why is .qgz the default format?
Régis Haubourg
regis.haubourg at gmail.com
Fri Mar 22 07:56:45 PDT 2019
Sorry Rémi, I was anticipating.
This is harcoded right now and the option does not exists yet. I'm unsure
if adding an option can be backported to QGIS 3.4 unfortunately.
Bes regards
Régis
Le ven. 22 mars 2019 à 15:29, Régis Haubourg <regis.haubourg at gmail.com> a
écrit :
> Hi Rémi,
> you can use the global settings ini file to override default option for
> QGIS.
> There is an option to start QGIS with another default setting file
> --globalsettingsfile
> https://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_configuration.html#running-qgis-with-advanced-settings
> You can have a look at how the french ministry of ecology handles this
> issue here:
> http://www.geoinformations.developpement-durable.gouv.fr/qgis-package-3-4-2-pour-test-a3662.html
> Best regards,
> Régis
> Le ven. 22 mars 2019 à 15:14, Rémi Bovard <remi.bovard at gmail.com> a
> écrit :
>> Hi all,
>> Matthias Kuhn 🌍 wrote
>> > Currently I'm inclined to prefer Andreas' proposal to have a
>> > (well-hidden advanced) setting to let power-users and admins switch the
>> > default format.
>> I would like to know if this possiblity of using a setting to set default
>> format has been implemented?
>> I'm currently planing to upgrade our 50+ QGIS 2.18 to QGIS 3.4 with a
>> custom
>> QGIS3.ini and I really want to be able to set default project format to
>> *.qgs.
>> Like Andreas, sometimes I need to do some mass projects edits (currently
>> we
>> have 150+) and it works well with a global `search and replace` with
>> Notepad++. The workaround proposed by Jorge Gustavo Rocha could be fine to
>> edit 1 file but not for a mass edit.
>> Thanks in advance for your answer.
>> Rémi
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190322/326341bf/attachment.html>
