[QGIS-Developer] Sort order for Value Map widget values
Andreas Neumann
a.neumann at carto.net
Fri Mar 22 08:04:50 PDT 2019
The alternative (workaround) is to put your values in another table and
link them through a shared key. Then the sorting works fine. Also the
relation reference widget (which requires a relation) sorts values fine.
Of course this doesn't mean the bug in the value map shouldn't be fixed.
You can ask a developer familiar with the widgets (e.g. Matthias or
someone else familiar with the widgets) to fix it, as part of our bug
fixing program.
Greetings,
Andreas
Am 22.03.19 um 15:26 schrieb Giovanni Manghi:
> I am using a value map lookup to let the user select a month on a
> form. I used the ‘Load Data from Layer option and the months are
> displayed in a somewhat random looking order. Is there any trick
> to getting the values to display in ascending order of the key? Or
> is this a bug?
> Hi Tim,
> is a long standing bug.
> cheers!
> -- G --
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190322/f9cd2310/attachment-0001.html>
