[QGIS-Developer] Can't import GeoPackage generated by QGIS into	PostGIS
    Alessandro Pasotti
    apasotti at gmail.com
    Sat Mar 30 14:11:21 PDT 2019
On Sat, Mar 30, 2019, 21:55 Anita Graser <anitagraser at gmx.at> wrote:
> Hi,
> I have a CSV with multiple columns including some WKT columns containing
> polygon definitions. I've exported the layer as GeoPackage. Later, I wanted
> to import the GeoPackage content to PostGIS but the import fails because
> the WKT strings are longer than the fields DB Manager creates. The layer
> properties state that the WKT columns are text(255) but the strings are
> considerably longer.
> (If I directly import the CSV to PostGIS, all is well.)
> I'm not sure what kind of ticket I should open ...
> - Option #1: DB Manager should be more fault tolerant and create less
> restrictive columns
> - Option #2: QGIS shouldn't create GeoPackages that store long strings in
> field defined as text(255)
> What do you recommend?
Hi Anita,
I think 2 looks like a bug.
I didn't look at it but from your description seems like DB manager
correctly follows the (wrong) information from the provider.
> Regards,
> Anita
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190330/cba409fb/attachment.html>
