[QGIS-Developer] Converting to GeoJson missing Z value
matteo
matteo.ghetta at gmail.com
Thu May 2 23:04:45 PDT 2019
Hi all,
when I convert a layer (gpx, 25D shp, etc) to a geojson I noticed that
the geojson file is missing the Z value.
Even when using the drape algorithm and directly saving the output as
geojson, no z values are there.
Is this a limitation of the driver or are some tricks I should use?
BTW: in the saving dialog the "Include z dimension" is checked even if
not active.
Cheers and thanks
Matteo
