[QGIS-Developer] RES: show error message without exiting the plugin
Jorge Almerio
jorgealmerio at yahoo.com.br
Fri May 3 07:29:11 PDT 2019
I think in this case, as you do not want to close your gui, you should put the message bar in your gui, I suppose it's a dialog.
you have a code sample in Qgis cookbook <https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/communicating.html> , may it can help you:
class MyDialog(QDialog):
def __init__(self):
QDialog.__init__(self)
self.bar = QgsMessageBar()
self.bar.setSizePolicy( QSizePolicy.Minimum, QSizePolicy.Fixed )
self.setLayout(QGridLayout())
self.layout().setContentsMargins(0, 0, 0, 0)
self.buttonbox = QDialogButtonBox(QDialogButtonBox.Ok)
self.buttonbox.accepted.connect(self.run)
self.layout().addWidget(self.buttonbox, 0, 0, 2, 1)
self.layout().addWidget(self.bar, 0, 0, 1, 1)
def run(self):
self.bar.pushMessage("Hello", "World", level=Qgis.Info)
De: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Em nome de Roberta Fagandini
Enviada em: sexta-feira, 3 de maio de 2019 10:45
Para: qgis-developer at lists.osgeo.org
Assunto: [QGIS-Developer] show error message without exiting the plugin
Hi all,
I'm developing a plugin and I need to check if some features of the input vector layer are selected or not. If not I'd like to show an error message without closing the plugin gui:
This is the code at the moment:
if self.dlg.checkBox.isChecked():
check_sel = selectedLayer2.selectedFeatureCount()
if check_sel > 0:
intersec_layer = QgsProcessingFeatureSourceDefinition(selectedLayer2.id(), True)
else:
self.iface.messageBar().pushCritical("Error", "No features selected in layer {}.".format(selectedLayer2.name()))
return
Any idea?
Thanks
Roberta
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190503/2bddbb60/attachment-0001.html>
