[QGIS-Developer] Building QGIS with Ninja on Windows - python37_d.lib
Jürgen E. Fischer
jef at norbit.de
Tue May 7 09:27:01 PDT 2019
Hi Olivier,
On Tue, 07. May 2019 at 18:15:38 +0200, Olivier Dalang wrote:
> It looks like it can't link to python37_d.lib. I checked, but couldn't find
> the file in OSGeo4W64\apps\Python37\libs nor on my system's python, so I
> installed the python debug binaries (using the normal python installers for
> windows), and tried to copy the file over to the OSGeo4W python install,
> but it didn't work. I still get the same error, and some other messages
> that may be linked).
Are you trying debug builds? Try RelWithDebInfo instead.
You can also use package-nightly.cmd to create packages. That will also use
ninja and leave a build directory around, which you can also use for
development.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190507/d4c29f4a/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190507/d4c29f4a/attachment.ksh>
