[QGIS-Developer] Can I backport bugfix with UI updates and fixing QGIS Server regression
    René-Luc Dhont
    rldhont at gmail.com
    Fri May 10 01:31:30 PDT 2019
Hi devs,
I am still waiting for a review about fixing 2 issues in printing for
QGIS and QGIS Server 3.4 LTR. https://github.com/qgis/QGIS/pull/9692
This PR wil fix an issue https://issues.qgis.org/issues/19500 `Layout
export - raster divided into tiles, edges evident in pdf/svg`. This
issue has been identifed in version 3.2 and has been fixed in 3.6.
This PR will also fix a regression in QGIS Server `Printing selection in
PDF and SVG`. The selection is already printed in image output.
The next LTR will be released in 10 mounths. QGIS Server 3.6, which
already have the fix, is not available on Debian Stretch because it
requires Qt 5.9 and Debian Buster will be freezed in 8 mounths. So the
QGIS server regression will not be available since the end of 2019.
I will appreciate a decision about this fix. Do you think QGIS Server
users have to wait for the next LTR or Debian Buster release ?
Reagrds,
René-Luc
Le 19/04/2019 à 09:34, René-Luc Dhont a écrit :
> Hi devs,
> I have cherry-picked the changes
> I have tested it without regressions or issues.
> Now I need some review to merge and fix 2 issues.
> Regards,
> René-Luc
> Le 17/04/2019 à 14:18, René-Luc Dhont a écrit :
>> Hi devs,
>> Thanks Paolo for your agreement.
>> I'd like to fix the QGIS Sever regression before friday and the
>> version 3.4.7 released.
>> So I'd like to have other point of view  about backporting :
>> [needs-docs][layouts] Add checkbox to disable raster tiling for
>> PDF/SVG exports https://github.com/qgis/QGIS/pull/9016
>> and finalizing Fix regression server print selection pdf release 3.4
>> Thanks.
>> René-Luc
>> Le 12/04/2019 à 12:06, Paolo Cavallini a écrit :
>>> Hi René,
>>> On 12/04/19 12:05, René-Luc Dhont wrote:
>>>> I would like to know if I can backport all the commits made by
>>>> Nyall to
>>>> fix issue 19500 even if it updates the User Interface ?
>>> +1 from my side, but obviously Nyall has the final word on this.
>>> Thanks.
