[QGIS-Developer] Questions wrt. problems with empty layers
Alessandro Pasotti
apasotti at gmail.com
Fri May 10 08:10:24 PDT 2019
On Fri, May 10, 2019 at 5:04 PM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> Hi,
> Just tried with a Geoserver (2.15) I have running here.
> Moved a shp file with 1 feature in a postgis db, created a wfs service
> for it and loaded in QGIS, styled it etc: fine.
> Removed the (one) feature from the table, retarted Geoserver, and had a
> look into the requests QGIS is firing [0].
> QGIS first does a GetCapabilities request:
> /geoserver/wfs?SERVICE=WFS&REQUEST=GetCapabilities&ACCEPTVERSIONS=2.0.0,1.1.0,1.0.0
> Then a describefeature request (to determine the type):
> geoserver/wfs?SERVICE=WFS&REQUEST=DescribeFeatureType&VERSION=2.0.0&TYPENAME=test:wfspointPostgis
> That one responses with
> <xsd:element maxOccurs="1" minOccurs="0" name="geom" nillable="true"
> type="gml:PointPropertyType"/>
> So Geoserver (still?) knows about the geometry type of the table.
> Not sure if that is cached? But it is available in the
> 'geometry_columns'-view of Postgis (stating type=POINT).
> And QGIS keeps the styling, even after several restarts/reloads.
> One thing I can think of: is that the postgis table does not have a type
> defined, with someting like:
> geom geometry
> instead of
> geom geometry(Point,28992),
> what I see when the table created via QGIS...
> Could it be that
> - geoserver cannot determine the type?
> To test I created a minimal table:
> CREATE TABLE public.testgeoms
> id integer,
> geom geometry,
> fid integer NOT NULL DEFAULT nextval('testgeoms_fid_seq'::regclass),
> CONSTRAINT foo PRIMARY KEY (fid)
> At that moment the geometry_columns view shows type=GEOMETRY
> So (I think) without data, geoserver can never determine the type, hence
> shows:
> type="gml:GeometryPropertyType"/>
> in the DescribeFeatureType response...
> And indeed if I then empty the table, and reopen the project the
> WFS-point layer shows an 'img', as it cannot style the zero features.
> AND it does not have type info?
> So (confirmed) having that layer with zero (of unknown type) features,
> QGIS forgets the style...
> Is that a bug?
QGIS styles are bound to geometry types, it the type is unknown there is
not much we can do .... something similar happens for bad/broken layers.
For that implementation I'm storing the original XML layer style that can
be re-applied in case the "bad layer" is fixed, maybe we can re-use that
mechanism for this use case.
> IF you create the layers with a feature TYPE (geom
> geometry(Point,28992)) then the type will show up in the
> 'geometry_columns'-view and then in the describefeature response.
> Without that knowledge QGIS retrieves NO type information (via the
> describefeature) upon loading of the project/layer and (apparently)
> forgets the type in the layer???
> Does it work with you if you put the type in the table definitions in
> Postgis (so they show up in the 'geometry_columns'-view)?
> With me it does, but I just did a quick test.
> Else I would create an issue for it or let somebody dive into this...
> Regards,
> [0] https://github.com/rduivenvoorde/qgisnetworklogger/tree/model_rewrite
> On 09/05/2019 22.22, Bo Victor Thomsen wrote:
> > Hi Lars and other members of this list..
> > I feel somewhat obligated to help Lars since it's a problem he has
> > inherited from me. (Sorry about that...)
> > To sum it up:
> > If QGIS connects to a WFS based layer from Geoserver using an existing
> > project with styled layers and one or more layers containing /zero/
> > objects, QGIS can't determine the object type (point, line-string,
> > polygon...) for those layers. QGIS will not show legends and promptly
> > forget any layer information stored in the project related to the
> > object-type, ex. styling information.
> > And what is worse - this is a permanent situation: If you save the
> > project in the above-mentioned state and reopen it at a later time -
> > where the layers /now/ contains objects - QGIS has forgotten the styling
> > and other information, so the layers stays invisible and without the
> > former styling.
> > (long posting...)
> > I've done some tests to determine the root cause of this problem:
> > * Setup of a Postgres database /and /a SQL Server database.
> > * Loaded the same MapInfo-dataset twice into each database, called
> > them tableA and tableB, and populated the meta-table
> > "dbo.geometry_columns" with the correct information for tableA and
> > tableB in SQLServer.
> > * Installed a fresh Geoserver 2.15 and MapServer TinyOWS WFS-T server
> > * Setup a Workspace in Geoserver with 4 layers: tableA and -B from
> > SQLServer and the same tables from Postgres using WFS.
> > * In Geoserver, the datastore definition for the SQLServer tables has
> > a pointer to the "dbo.geometry_columns" meta-table.
> > * Setup of TinyOWS with tableA and -B from Postgres
> > * And lastly: Made a project in QGIS 3.4.7 /Windows 64bit with the 6
> > WFS layers:
> > o tableA is shown 3 times:
> > 1. From SQLServer through GeoServer;
> > 2. From Postgres through GeoServer
> > 3. From Postgres through Tiny-WFS
> > o tableB is shown 3 times using the same setup as tableA
> > All 6 layers in QGIS was shown correctly and the object type for all
> > layers was recognized.
> > After this I /deleted/ all rows from tableB in /both/ MS-SQLServer and
> > in Postgres and reopened the same QGIS project:
> > * The layer showing (the zero objects) tableB from SQLServer through
> > GeoServer was not in order.
> > * The 5 other layers was shown correctly. Legends was correct and
> > styling was not deleted
> > I'm drawing the following conclusion:
> > * GeoServer WFS connections (maybe in conjunction with QGIS) doesn't
> > work properly when the dataprovider is MS-SQLServer and the layers
> > contains zero objects. More precisely: GeoServer's SQLServer
> > dataprovider can't or don't use geometry_columns meta-table defined
> > in the datastore as described in:
> https://docs.geoserver.org/stable/en/user/data/database/sqlserver.html#using-the-geometry-metadata-table
> > After this test I've tried to change the placement and existence of the
> > "geometry_columns" metadata table:
> > * No value
> > * dbo.geometry_column (ordinary placement)
> > * data.geometry_column (I made a copy of the geometry_columns table
> > and placed it in the same schema as the test tables)
> > * geometry_columns (without schema definition)
> > Nothing of the above worked.
> > @Lars:
> > You might change your database system to Postgres and perhaps replace
> > GeoServer with TinyOWS for WFS purposes (ducks and and run....) .
> > Or getting the issue investigated and fixed using some GeoServer core
> > developer, perhaps in cooperation with a QGIS core developer?
> > Apparently the problem is fixable, since neither TinyOWS or
> > GeoServer/Postgres have the same issues.
> > Obviously, the above is a far cry from a really rigorous investigation
> > of the problem, but it points at some of the "pain" points
> > Regards
> > Bo Victor Thomsen
> > AestasGIS
> > Denmark
> > Den 09-05-2019 kl. 13:36 skrev Lars I. Nielsen, LIFA A/S:
> >> Hi developers.
> >> I asked this question on the user’s list, so far without any answers,
> >> but have been advised to ask here as well.
> >> I’m working with a number of projects, which statically open a fixed
> >> number of layers. All layers are fetched using WFS / WFS-T.
> >> Each layer has an extensive rule based styling, and an extensive
> >> field/attribute dialog setup. This is saved in the project files.
> >> Our plugin changes the data provider filter for many layers, when the
> >> user works with the data. These filter expressions are also saved in
> >> the project, of course.
> >> Our problem is, that if the user accidently chooses a work area (= new
> >> data provider filter), which contain no data in any layer, those
> >> layers lose all styling etc. And it’s apparently impossible to recover
> >> these styles etc. by changing the filter back.
> >> So basically the user’s project is unrecoverably trashed at this point
> >> in time.
> >> A - Is this a correct description of how QGIS handles “no-data” layers ?
> >> B - Are there any standard ways to handle this in QGIS (using metadata
> >> or otherwise) in an automated fashion (i.e. not manually) ?
> >> C - If the answers to A and B are yes and no resp., are there any
> >> plans to remedy this unnecessarily serious problem ?
> >> Might it not be solved simply by adding an (optional?) layer metadata
> >> key, that stores the last used topology, and revert to this if no data
> >> are found on the layer ?
> >> Using 3.4.5 x64 (Danish)
> >> Med venlig hilsen
> >> GIS-konsulent, FME Certified Professional
> >> Beskrivelse: http://website.lifa.dk/lsp.gif
> >> *T*
> >> 6313 6800
> >> lin at lifa.dk
> >> *D*
> >> 6313 6849
> >> *W*
> >> www.lifa.dk <http://www.lifa.dk>
> >> *M*
> >> 2492 4866
> >> *CVR*
> >> 20937289
> >> Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-Images-Get-L749-l8.png
> >> <https://www.linkedin.com/company/lifa-a-s/>
> >> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190510/e96fbcdf/attachment-0001.html>
