[QGIS-Developer] Can I backport bugfix with UI updates and fixing QGIS Server regression
Régis Haubourg regis.haubourg at gmail.com
Sun May 12 00:41:19 PDT 2019
Le dim. 12 mai 2019 à 07:32, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
> On Fri, 10 May 2019 at 18:31, René-Luc Dhont <rldhont at gmail.com> wrote:
> > Hi devs,
> > I am still waiting for a review about fixing 2 issues in printing for
> > QGIS and QGIS Server 3.4 LTR. https://github.com/qgis/QGIS/pull/9692
> > This PR wil fix an issue https://issues.qgis.org/issues/19500 `Layout
> > export - raster divided into tiles, edges evident in pdf/svg`. This
> > issue has been identifed in version 3.2 and has been fixed in 3.6.
> > This PR will also fix a regression in QGIS Server `Printing selection in
> > PDF and SVG`. The selection is already printed in image output.
> > The next LTR will be released in 10 mounths. QGIS Server 3.6, which
> > already have the fix, is not available on Debian Stretch because it
> > requires Qt 5.9 and Debian Buster will be freezed in 8 mounths. So the
> > QGIS server regression will not be available since the end of 2019.
> > I will appreciate a decision about this fix. Do you think QGIS Server
> > users have to wait for the next LTR or Debian Buster release ?
> I'm still uncomfortable with the potential risk this has of breaking
> layout export in 3.4 for desktop users. So I'm not going to approve
> the backport, but if another dev is willing to take on this risk and
> approve the backport then I won't stand in the way.
> Nyall
I agree with Nyall here unfortunately.
Backporting this could be acceptable at the condition of having a wide
integration test coverage and extensive real testing of the fixed branches.
I'd be pleased to test things here but use cases are so numerous that I
fail to see how to do this efficiently.
I hope we'll one day be able to run those smoke tests as discussed at La
Coruna.
Best regards
Régis
> > Reagrds,
> > René-Luc
> > Le 19/04/2019 à 09:34, René-Luc Dhont a écrit :
> > > Hi devs,
> > > I have cherry-picked the changes
> > > I have tested it without regressions or issues.
> > > Now I need some review to merge and fix 2 issues.
> > > Regards,
> > > René-Luc
> > > Le 17/04/2019 à 14:18, René-Luc Dhont a écrit :
> > >> Hi devs,
> > >> Thanks Paolo for your agreement.
> > >> I'd like to fix the QGIS Sever regression before friday and the
> > >> version 3.4.7 released.
> > >> So I'd like to have other point of view  about backporting :
> > >> [needs-docs][layouts] Add checkbox to disable raster tiling for
> > >> PDF/SVG exports https://github.com/qgis/QGIS/pull/9016
> > >> and finalizing Fix regression server print selection pdf release 3.4
> > >> Thanks.
> > >> René-Luc
> > >> Le 12/04/2019 à 12:06, Paolo Cavallini a écrit :
> > >>> Hi René,
> > >>> On 12/04/19 12:05, René-Luc Dhont wrote:
> > >>>> I would like to know if I can backport all the commits made by
> > >>>> Nyall to
> > >>>> fix issue 19500 even if it updates the User Interface ?
> > >>> +1 from my side, but obviously Nyall has the final word on this.
> > >>> Thanks.
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190512/95634b37/attachment-0001.html>
More information about the QGIS-Developer mailing list
