[QGIS-Developer] How do I add a QgsLayoutItemMapGrid to a QgsLayoutItemMap with PyQGIS 3.x?
Nyall Dawson
nyall.dawson at gmail.com
Mon May 13 16:14:20 PDT 2019
On Tue, 14 May 2019 at 01:13, Damián Ortega Terol <dortegat at gmail.com> wrote:
> I'm trying to add a grid to a map but I don't get any results. My code:
> def add_map_layout_item(self,
> list_maplayers,
> qgs_rectangle,
> origin_x_mm,
> origin_y_mm,
> width_mm,
> height_mm,
> grid_interval):
> map = QgsLayoutItemMap(self.layout)
> map.updateBoundingRect()
> map.setRect(QRectF(origin_x_mm, origin_y_mm, width_mm, height_mm))
> map.setPos(origin_x_mm, origin_y_mm)
> map.setFrameEnabled(True)
> map.setLayers(list_maplayers)
> map.setKeepLayerSet(True)
> map.setExtent(qgs_rectangle)
> self.iface.mapCanvas().freeze(True)
> map.attemptMove(QgsLayoutPoint(origin_x_mm, origin_y_mm))
> map.attemptResize(QgsLayoutSize(width_mm, height_mm))
> map.zoomToExtent(qgs_rectangle)
> qgs_layout_item_map_grid = QgsLayoutItemMapGrid("New grid",
> map)
> qgs_layout_item_map_grid.setAnnotationPrecision(0)
> qgs_layout_item_map_grid.setAnnotationFrameDistance(1)
> qgs_layout_item_map_grid.setAnnotationFontColor(QColor(0, 0, 0))
> qgs_layout_item_map_grid.setCrossLength(1.0)
> qgs_layout_item_map_grid.setIntervalX(grid_interval)
> qgs_layout_item_map_grid.setIntervalY(grid_interval)
You need to add your grid to the map item:
map.grids().addGrid(qgs_layout_item_map_grid)
Nyall
> self.layout.addLayoutItem(map)
> What am I missing?
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
