[QGIS-Developer] save QgsRasterCalculator output file in ascii format (.asc and .xyz)
Roberta Fagandini
robifagandini at gmail.com
Thu May 16 03:30:31 PDT 2019
Hi devs,
I'm using the QgsRasterCalculator within a python plugin and I would like
to save the output file in ascii format but it seems to be not available.
Is it right?
A solution could be to save the output file as virtual raster and then
translate it. Are there other possible solution to directly save the output
in ascii format or to speed up the process?
Thanks in advance,
Roberta
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190516/fd1a8483/attachment.html>
