[QGIS-Developer] FeatureSink, Processing and Geopackage : define layer primary key
René-Luc Dhont rldhont at gmail.com
Mon May 20 05:02:49 PDT 2019
Hi devs,
I'd like to save data in a Geopackage by defining the layername, the
geometry column and the primary key field with a processing parameter
feature sink.
I have found in the processing tests, that a feature sink value can be :
ogr:dbname='/me/a.gpkg' table="d" (geom) sql=
Is it possible to define the primary key field ?
Regards,
René-Luc
More information about the QGIS-Developer mailing list
