[QGIS-Developer] Help fixing code for gcc 4.8
Henrik K
hege at hege.li
Thu May 23 00:01:33 PDT 2019
I'm almost near finishing, but qgswmsrenderer.cpp is throwing a lot of
errors (for bot 3.4.8 and 3.6.3). Could someone have a look at this:
https://pastebin.com/JS7uKAZ7
The two expression errors there I fixed per previous advice..
const auto { } -> ( )
Cheers,
Henrik
On Wed, May 22, 2019 at 10:50:47AM -0700, Elias Carter wrote:
> > But if I manage to get this running I'll post all my patches somewhere.
> Hi Henrik,
> I would be interested in collaborating with you to get QGIS 3 running on RHEL/
> CentOS 7.
> Would you be willing to share your current patchset and maybe I can help out
> with getting this working?
> Thanks,
> Elias
> On Wed, May 22, 2019 at 10:40 AM Henrik Krohns <[1]hege at hege.li> wrote:
> Thanks, it worked, so simple..
> Are fixes like this good canditate to actually raise an issue? I have no
> clue
> on all the C++ versions etc and what stuff is legacy not intended to use
> these days..
> On Wed, May 22, 2019 at 05:40:45PM +0200, Alessandro Pasotti wrote:
> > Hi Henrik,
> > Try to replace {} with (), such as:
> > const auto treeLayer ( static_cast<const QgsLayerTreeLayer *>( childNode
> > On Wed, May 22, 2019 at 4:42 PM Henrik Krohns <[1][2]hege at hege.li> wrote:
> > Hello,
> > I've been trying to compile QGis on RHEL7 / GCC 4.8.5 all day. It
> seems
> > lots of code assume newer compiler. I've fixed many cases already,
> but
> > here's something I can't manage.. not really proficient in C++..
> > src/server/services/wms/qgswmsgetcapabilities.cpp: In function 'bool
> > QgsWms::hasQueryableChildren(const QgsLayerTreeNode*, const
> QStringList&)':
> > src/server/services/wms/qgswmsgetcapabilities.cpp:1893:31: error:
> base
> > operand of '->' has non-pointer type 'const std::initializer_list
> <const
> > QgsLayerTreeLayer* const>'
> > const auto l { treeLayer->layer() };
> > src/server/services/wms/qgswmsgetcapabilities.cpp:1893:41: error:
> unable to
> > deduce 'const std::initializer_list<const auto>' from '{<expression
> error>}
> > The code..
> > else if ( childNode->nodeType() == QgsLayerTreeNode::NodeLayer )
> > const auto treeLayer { static_cast<const QgsLayerTreeLayer *>(
> > childNode ) };
> > return ! wmsRestrictedLayers.contains( l->name() ) && l->flags
> > ().testFlag( QgsMapLayer::Identifiable );
> > Any ideas how to rewrite?
> > Cheers,
> > Henrik
> > QGIS-Developer mailing list
> > [2][3]QGIS-Developer at lists.osgeo.org
> > List info: [3][4]https://lists.osgeo.org/mailman/listinfo/
> qgis-developer
> > Unsubscribe: [4][5]https://lists.osgeo.org/mailman/listinfo/
> qgis-developer
> > Alessandro Pasotti
> > w3: [5][6]www.itopen.it
> > References:
> > [1] mailto:[7]hege at hege.li
> > [2] mailto:[8]QGIS-Developer at lists.osgeo.org
> > [3] [9]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > [4] [10]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > [5] [11]http://www.itopen.it/
> [12]QGIS-Developer at lists.osgeo.org
> List info: [13]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: [14]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> References:
> [1] mailto:hege at hege.li
> [2] mailto:hege at hege.li
> [3] mailto:QGIS-Developer at lists.osgeo.org
> [4] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [5] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [6] http://www.itopen.it/
> [7] mailto:hege at hege.li
> [8] mailto:QGIS-Developer at lists.osgeo.org
> [9] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [10] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [11] http://www.itopen.it/
> [12] mailto:QGIS-Developer at lists.osgeo.org
> [13] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [14] https://lists.osgeo.org/mailman/listinfo/qgis-developer
