[QGIS-Developer] Locale settings is not applied to custom build
黄 克鲁 tone90999 at hotmail.com
Thu May 23 19:10:13 PDT 2019
After building QGIS using CMake and Visual Studio 2017 (with 2015 toolset), I can't set QGIS language to any language other than English, even when I change the language settings from Options dialog (see picture below):
[cid:3761a9a8-4897-49db-9c8a-9f26304143f0]
This option has almost no effect - only the Raster and Vector menu items are partially translated (see picture below):
[cid:cd98c153-f310-439c-ba38-46cad963af9c]
The last two items in Chinese mean "Raster" and "Vector", respectively.
This problem happens on 3.4 LTR only - on my machine. I didn't run into this problem when I was building 3.2 or 3.4.1. It also doesn't happen on the build directly downloaded from OSGeo4W.
To run QGIS properly, I have qgis.env placed on the same directory containing qgis.exe. I have attached the file in this mail.
My building environment:
Windows 10 Enterprise version 1809 (64-bit), with SDK version 17763;
CMake 3.11;
Visual Studio 2017 (with 2015 toolset installed);
All dependencies, including Qt 5.11, are installed totally via OSGeo4W (64-bit) or latest Cygwin.
I'm really confused on this problem, if anyone has a solution, please let me know.
Winfred Huang
24/5/2019
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190524/e812cca0/attachment-0001.html>
Name: Untitled Project - QGIS 2019-05-24 09.55.12.png
Type: image/png
Desc: Untitled Project - QGIS 2019-05-24 09.55.12.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190524/e812cca0/attachment-0002.png>
Name: Options _ General 2019-05-24 09.59.56.png
Type: image/png
Desc: Options _ General 2019-05-24 09.59.56.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190524/e812cca0/attachment-0003.png>
Type: application/octet-stream
Desc: qgis.env
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190524/e812cca0/attachment-0001.obj>
More information about the QGIS-Developer mailing list
