[QGIS-Developer] qgis_editor_widget_styles table, what is it ? How to create it?
Régis Haubourg
regis.haubourg at gmail.com
Fri May 24 01:24:31 PDT 2019
Hi all,
I'm facing very slow opening of project files for a customer here in QGIS
3.4.5. Something like 7 minutes, against 30 s in QGIS 2.18.
We are still investigating to narrow it down, but I faced a first query in
the logs that I fail to understand.
QGIS emits this at a point:
select count(*)
from information_schema.tables
where table_name = 'qgis_editor_widget_styles' ;
And this query is long in our context, 1.7s, because of a very high number
of tables and schemas in that production DB.
I found at [0] in the postgres provider where it comes from, I found the
associated PR [1], but I fail to understand in what workflow this table is
created using QGIS, and what it is used for.
Can someone put some light here ?
Best regards
Régis
[0]
https://github.com/qgis/QGIS/blob/master/src/providers/postgres/qgspostgresprovider.cpp#L1083
[1] https://github.com/qgis/QGIS/pull/3439
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190524/133dd79f/attachment.html>
