[QGIS-Developer] github comment issues
Richard Duivenvoorde rdmailings at duif.net
Fri May 24 14:24:08 PDT 2019
At this moment we are running the script to fill github/qgis
issuetracker with the issues from Redmine.
So this limited interaction is/should be for a limited time.
See:
https://lists.osgeo.org/pipermail/qgis-developer/2019-May/057383.html
and
https://github.com/qgis/QGIS-Enhancement-Proposals/issues/141#issuecomment-478296818
The github api we use is was rather slow this morning, but the plan was
to do the migration within 24 hour..
Jorge probably will let us know when finished.
Regards,
On 24/05/2019 22.52, Harrissou wrote:
> Hi,
> My case too. Only committers can interact, currently. I Sent a message
> to the list earlier but attached image was too big (hence failed to
> reach the list) and didn't have time to resend.
> Regards,
> Harrissou
> Le 24 mai 2019 22:39:03 GMT+02:00, "Alexis R.L." <alroyliz0 at gmail.com> a
> écrit :
>     Greetings,
>     When I go on my PRs or any issue or PR I see the following:
>     I'm not sure if this is intended but I cannot comment on anything,
>     I'm not sure if this is me in particular or for any other
>     non-collaborator as the message says.
>     Was this intended?
>     Alexis Roy-Lizotte
> Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser
> ma brièveté.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
