[QGIS-Developer] qgis_editor_widget_styles table, what is it ? How to create it?
Régis Haubourg
regis.haubourg at gmail.com
Sat May 25 08:48:03 PDT 2019
Hi, Thanks Nyall for the hints.
I'm considering switching to this query instead.
SELECT * FROM pg_class WHERE relname='qgis_editor_widget_styles'
In my setup it access only to one table and uses internal indexes, when the
information_schema.tables is a view that involve a materialized query here
when using explain.
I don't see a significant difference on my local setup, I'll test it on our
customer setup before starting my (first) PR!
Cheers
Régis
Le sam. 25 mai 2019 à 05:33, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
> On Fri, 24 May 2019 at 18:25, Régis Haubourg <regis.haubourg at gmail.com>
> wrote:
> > Hi all,
> > I'm facing very slow opening of project files for a customer here in
> QGIS 3.4.5. Something like 7 minutes, against 30 s in QGIS 2.18.
> > We are still investigating to narrow it down, but I faced a first query
> in the logs that I fail to understand.
> > QGIS emits this at a point:
> > And this query is long in our context, 1.7s, because of a very high
> number of tables and schemas in that production DB.
> > I found at [0] in the postgres provider where it comes from, I found the
> associated PR [1], but I fail to understand in what workflow this table is
> created using QGIS, and what it is used for.
> > Can someone put some light here ?
> There's a unit test at
> https://github.com/qgis/QGIS/pull/3439/files#diff-99b101819133a316786604243f3abf6eR318
> and
> https://github.com/qgis/QGIS/pull/3439/files#diff-03e6d7f6f76fb4bcab508984d0fd05f6R443
> which partially explains this -- it looks like it's a way to specify a
> default editor widget configuration for a table, which is used
> whenever that table is loaded into QGIS.
> > select count(*)
> > from information_schema.tables
> > where table_name = 'qgis_editor_widget_styles' ;
> Looks like that query could be substantially improved -- it's only
> testing for existence of the table, so calculating the count is
> inefficient and requiring a whole table scan.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190525/3857292d/attachment.html>
