[QGIS-Developer] Tests failing
Alessandro Pasotti
apasotti at gmail.com
Fri Nov 1 04:55:59 PDT 2019
Thank you for the update!
And for fixing it ;)
On Fri, Nov 1, 2019, 12:38 Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi again,
> It's fixed and the backport to 3.10 is in the pipeline.
> If you have some failed tests from the last 12 hours, please close and
> reopen your pull request which will trigger a new test run with this fix
> included.
> Enjoy the Friday
> Matthias
> On 11/1/19 12:17 PM, Matthias Kuhn wrote:
> *Public service announcement*
> All tests are currently failing.
> The root cause of it is that an external service has changed the download
> location for a tool that we run tests against.
> We are working on this and the infrastructure if all goes well, the
> infrastructure is back up and running soon.
> Kind regards
> Matthias Kuhn
> +41 (0)76 435 67 63 <+41764356763>
> [image: OPENGIS.ch Logo] <http://www.opengis.ch>
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191101/688408c1/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191101/688408c1/attachment.png>
