[QGIS-Developer] WinGRASS build up (WIP)
Jürgen E. Fischer
jef at norbit.de
Mon Nov 4 09:39:19 PST 2019
Hi Martin,
I added "experimental" packages to OSGeo4W (ie. only available if you tick Exp
in the OSGeo4W installer):
- PROJ 6.2.1
- GDAL 3.0.2
- liblwgeom 3.0.0
- OGDI 4.1.0
- Rebuilds of QGIS 3.10.0, QGIS 3.4.13 and spatialite 4.3.0a against the above
packages
- Backward compatibility packages gdal204dll and proj5dll that carry the original
DLLs from PROJ 5.2.0 and GDAL 2.4.1
The only missing bit is GRASS built against new GDAL and PROJ. Once that's is
available I can remove the "experimental" tag.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191104/0b242359/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191104/0b242359/attachment.ksh>
