[QGIS-Developer] Reading out-of-db PostgreSQL Raster
Jorge Gustavo Rocha jgr at di.uminho.pt
Tue Nov 5 12:34:44 PST 2019
Hi Paolo,
If you have GDAL >= 2.4, it should work. Can you check your GDAL version?
Do you also have overviews/pyramids? The overviews should work, because
they are in db. Only the original raster is out-of-db.
Regards,
Jorge
Às 20:24 de 05/11/19, Paolo Cavallini escreveu:
> Hi all,
> loading PostGIS rasters from the browser works very well, thanks Ale!
> However, those loaded with the -R option (out of db rasters) throw an error:
> Warning: Logged warning: RasterIO error:
> PostGISRasterRasterBand::IRasterIO(): ERROR:  rt_band_load_offline_data:
> Cannot open offline raster:
> /home/paolo/Documents/Didattica/Corsi_Formazione_Faunalia/PostGIS/data/dtm_nord.tif
> I have enabled out-of-db rasters:
>  POSTGIS_ENABLE_OUTDB_RASTERS=1
>  POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL
> The same data are readable from psql
> select * from dtm_ext ;
> │ rid │
> │   1 │ 01000001...
> Is this a known limitation, or do I need some additional config?
> Thanks.
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
More information about the QGIS-Developer mailing list
