[QGIS-Developer] Reading out-of-db PostgreSQL Raster
Paolo Cavallini
cavallini at faunalia.it
Tue Nov 5 23:37:21 PST 2019
/me stupid: postgresql did not have read access to the file.
sorry for the noise
Il 06/11/19 08:18, Paolo Cavallini ha scritto:
> Hi Jorge,
> Il 05/11/19 21:34, Jorge Gustavo Rocha ha scritto:
>> If you have GDAL >= 2.4, it should work. Can you check your GDAL version?
> 2.4.2+dfsg-2
>> Do you also have overviews/pyramids? The overviews should work, because
>> they are in db. Only the original raster is out-of-db.
> sure, all "normal" rasters, incluging the pyramids, are correctly shown.
> thanks for the feedback.
>> Às 20:24 de 05/11/19, Paolo Cavallini escreveu:
>>> Hi all,
>>> loading PostGIS rasters from the browser works very well, thanks Ale!
>>> However, those loaded with the -R option (out of db rasters) throw an error:
>>> Warning: Logged warning: RasterIO error:
>>> PostGISRasterRasterBand::IRasterIO(): ERROR: rt_band_load_offline_data:
>>> Cannot open offline raster:
>>> /home/paolo/Documents/Didattica/Corsi_Formazione_Faunalia/PostGIS/data/dtm_nord.tif
>>> I have enabled out-of-db rasters:
>>> POSTGIS_ENABLE_OUTDB_RASTERS=1
>>> POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL
>>> The same data are readable from psql
>>> select * from dtm_ext ;
>>> │ rid │
>>> │ 1 │ 01000001...
>>> Is this a known limitation, or do I need some additional config?
>>> Thanks.
>> J. Gustavo
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
