[QGIS-Developer] Geopackage as QGIS mapserver datasource failing?
Richard Duivenvoorde
rdmailings at duif.net
Wed Nov 6 00:55:21 PST 2019
I'm trying to get QGIS mapserver (master) here. All fine, untill I add a
Geopackage to the project.
Both with a simple gpkg (as in: create a polygon gpkg without any
attributes in QGIS) as in a more complex gpkg (the one I started with: 2
tables and a view).
GetCapabilities show:
<ServerException>Layer(s) not valid</ServerException>
Both gpkg's load/show fine in QGIS itself
Relevant log part (I think):
../src/core/qgsproject.cpp:1225 : (readProjectFile) [2ms] 43 properties
read
../src/core/qgsvectorlayer.cpp:1455 : (readXml) [3ms] Datasource in
QgsVectorLayer::readXml: /tmp/blaat.gpkg|layername=blaat
../src/core/providers/ogr/qgsogrprovider.cpp:475 : (QgsOgrProvider)
[1ms] Data source uri is [/tmp/blaat.gpkg|layername=blaat]
../src/core/providers/ogr/qgsogrprovider.cpp:273 : (AnalyzeURI) [0ms]
../src/core/providers/ogr/qgsogrprovider.cpp:4369 : (open) [0ms]
mFilePath: /tmp/blaat.gpkg
../src/core/providers/ogr/qgsogrprovider.cpp:4370 : (open) [0ms]
mLayerIndex: 0
../src/core/providers/ogr/qgsogrprovider.cpp:4371 : (open) [0ms]
mLayerName: blaat
../src/core/providers/ogr/qgsogrprovider.cpp:4372 : (open) [0ms]
mSubsetString:
../src/core/providers/ogr/qgsogrprovider.cpp:4425 : (open) [0ms] OGR
failed to opened in update mode, trying in read-only mode
../src/core/qgsmessagelog.cpp:29 : (logMessage) [0ms]
2019-11-06T09:46:34 OGR[1] Cannot open /tmp/blaat.gpkg.()
../src/core/qgsvectorlayer.cpp:1684 : (setDataProvider) [0ms]
Instantiated the data provider plugin
../src/core/qgsvectorlayer.cpp:1689 : (setDataProvider) [0ms] Invalid
provider plugin /tmp/blaat.gpkg|layername=blaat
../src/core/qgsvectorlayer.cpp:1490 : (readXml) [0ms] Could not set data
provider for layer /tmp/blaat.gpkg|layername=blaat
../src/core/qgsvectorlayer.cpp:2091 : (readSymbology) [0ms]
contextproject:layers:blaat_7cda99cd_6a97_4738_8e95_c0368d244004:fieldaliases
source fid
../src/core/qgsvectorlayer.cpp:2097 : (readSymbology) [0ms] field fid
origalias trans
../src/core/qgsproject.cpp:1061 : (addLayer) [1ms] Unable to load vector
layer
Should I create an issue?
Regards,
