[QGIS-Developer] Automatically install and update plugins
Alessandro Pasotti apasotti at gmail.com
Wed Nov 6 04:37:48 PST 2019
On Wed, Nov 6, 2019 at 1:27 PM <Bauer.Josef at swm.de> wrote:
> Hi Alessandro,
> thank you very much, that was exactly what we were looking for!
> Maybe it would be nice to put the QgsPluginInstaller also into the
> official API documentation (or in the “Deploying QGIS within an
> organization” documentation)? I could imagine that others also try to
> establish an “autoinstall/autoupdate” scenario.
I'm not sure we can add that information to the API docs, because that code
is not part of the stable API but it's something to consider for sure.
Btw, I've just found buried in the internet a work I've done a few years
ago when I was working for Boundless:
https://boundless-desktop.readthedocs.io/en/latest/system_admins/init_scripts.html#scripts-examples
It may be helpful for your use case (I think it's for QGIS 2.x but it
should be easily portable to QGI 3).
> Best regards,
> Josef
> *Von:* Alessandro Pasotti <apasotti at gmail.com>
> *Gesendet:* Mittwoch, 6. November 2019 12:21
> *An:* Bauer.Josef extern IT-DS-TS <Bauer.Josef at swm.de>
> *Cc:* QGIS Developer Mailing List <qgis-developer at lists.osgeo.org>
> *Betreff:* Re: [QGIS-Developer] Automatically install and update plugins
> On Wed, Nov 6, 2019 at 12:10 PM <Bauer.Josef at swm.de> wrote:
> Hi Allesandro,
> thank you for the answer. That sounds very promising. I think that is what
> we need.
> But can you tell me what exact Python API we have to use? I can’t find
> anything related to that topic in the API documentation [0] (we are using
> the LTR version QGIS 3.4).
> Yeah, there is not much QGIS core API for plugins management, it's mainly
> done in the Python side:
> https://github.com/qgis/QGIS/blob/master/python/pyplugin_installer/installer.py
> [0] https://qgis.org/pyqgis/3.4/index.html
> Tanks und kind regards,
> Josef
> *Gesendet:* Mittwoch, 6. November 2019 11:50
> On Wed, Nov 6, 2019 at 11:38 AM <Bauer.Josef at swm.de> wrote:
> Dear QGIS Developer,
> we have written some plugins that we would like to be installed and
> updated automatically (without any user interaction). We have also setup an
> internal plugins server. We can install the plugins from our plugin server
> manually, but is there also the possibility to install and update them
> without any user interactions (we have pre-configured the plugins in the
> QGIS3.ini)?
> basically, you need to create a custom startup py file and deploy it (it
> can also live on a network share), the startup script will contain the
> instructions (using the QGIS python API)
> to upgrade the plugins you need automatically.
> See the links for some more information:
> https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/intro.html#the-startup-py-file
> https://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_configuration.html#deploying-qgis-within-an-organization
> Hope this helps.
> Alessandro Pasotti
> w3:   www.itopen.it
> Alessandro Pasotti
> w3:   www.itopen.it
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191106/2e24fb3b/attachment.html>
More information about the QGIS-Developer mailing list
