[QGIS-Developer] Direct push forbidden to master
Sandro Santilli
strk at kbt.io
Fri Nov 8 03:36:12 PST 2019
On Fri, Nov 08, 2019 at 12:14:18PM +0100, Jürgen E. Fischer wrote:
> So I'm split - theoretically CI and tests are fine - practically they take up a
> lot of time to make, maintain and run - maybe more then they are worse - the
> sometimes (often?) breaks (unrelated to the actual commits) and breaking direct
> commits are also an edge case and not the rule. But save a lot of time - and
> also prevent people from making parallel PRs on the same issue.
I have the same experience: struggling with CI bots wasting lot
of time, having to re-base queued PRs on each merge to re-trigger
CI build and cross fingers they won't fail etc...
It's useful to have bots look after code but beware of them
taking over !
--strk;
