[QGIS-Developer] 3.10 packages for Debian testing/unstable are temporarily uninstallable
Bas Couwenberg
sebastic at xs4all.nl
Tue Nov 19 05:06:33 PST 2019
On 2019-11-19 13:56, Lior Kaplan wrote:
> When do we expect to have a rebuild of the Debian testing/unstable
> builds?
Should be fixed with the next release schedule for coming Friday.
This is a known issue with dependencies from testing/unstable as clearly
noted on the download page:
The release packages are only produced once shortly after a new version
has
been released. As unstable, not yet released debian versions (testing)
and
ubuntugis-unstable can have library changes the packages might sooner
or
later be broken for these targets, when the development in debian,
ubuntu or
ubuntugis-unstable moves on and their packages used as dependencies in
qgis
change. In that event you can either
* move to a stable debian version and use the released packages for
it,
* wait for the next point release (due 2019-11-22 12:00:00 UTC), which
happens every month and will include the updated dependencies,
* switch to a nightly repository (available for the two release
branches and master) whose packages are rebuild on regular basis and
will also pickup the updated dependencies automatically or
* build your own set of packages (see INSTALL).
https://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu
> The current packages at don't have this fix:
> https://github.com/qgis/QGIS/commit/f67369cc2639f513c77ef3e3c606f96294d9fa47
Note the followup:
https://github.com/qgis/QGIS/commit/8fedf7c72a3c1001783923f5c85e3c47fe72a011
Kind Regards,
Bas
