[QGIS-Developer] Auth-config and single sign-on with Windows login
Andreas Neumann a.neumann at carto.net
Wed Nov 20 08:10:46 PST 2019
Hi Jürgen,
I wouldn't know how this works. When I create a new PG connection, it
forces me to add a username and password. I can't create a new
connection without specifying one. Even if the Windows password manager
already knows my windows credentials, which are the same as the PG
credentials. As a "stupid user" I would either expect:
- not being asked for credentials (means that QGIS would automagically
forward the Windows credentials)
- or when creating a new auth-conf, having a choice like "use windows
credentials" and then not being asked for username/password, because
QGIS already knows it from Windows.
But maybe I am just not correctly handling it.
The one thing I noticed is that the Windows password manager
automatically loads the master password of the QGIS password manager. So
that one seems to work.
Andreas
On 2019-11-20 15:41, Jürgen E. Fischer wrote:
> Hi Andreas,
> On Wed, 20. Nov 2019 at 14:38:49 +0100, Andreas Neumann wrote:
>> Is it possible to use the Windows-Login as a login for PostgreSQL/WMS in the
>> auth-cfg manager?
> Are you sure support is even required?  I'd expect it to be handled
> transparently.
> Jürgen
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191120/83a25500/attachment.html>
More information about the QGIS-Developer mailing list
