[QGIS-Developer] [Qgis-user] Python Implementation of QgsNetworkContentFetcher
C Hamilton
adenaculture at gmail.com
Tue Nov 26 06:35:14 PST 2019
Thanks everyone. This gives me some good ideas. These are the possible
solutions:
1. Write a python implementation of QgsNetworkContentFetcher or
QgsBlockingNetworkRequest. With this I could look at the QGIS version and
if it is 3.10 or greater import the core method; otherwise, import the
python implementation.
2. Use the old Boundless implementation if it still works in QGIS 3.
3. Use QgsFileDownloader and save it as a temporary file before processing.
Calvin
On Tue, Nov 26, 2019 at 2:29 AM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> On Tue, Nov 26, 2019 at 8:22 AM Richard Duivenvoorde <rdmailings at duif.net>
> wrote:
>> On 26/11/2019 00.06, Nyall Dawson wrote:
>> > There's not. But there's the ex-boundless "networkaccessmanager"
>> > implementation that supports authcfg, which you can find at
>> https://github.com/north-road/qgis-redistricting-plugin/blob/master/redistrict/linz/networkaccessmanager.py
>> > (and other projects -- as far as I'm aware there's no real upstream
>> > for this... Alessandro?).
>> I used this Boundless thingie for several plugins now (original source
>> is now pointing/redirecting to planetlabs [0]).
> Yes, that's the "upstream" but I don't know if that one is maintained
> anymore.
> Btw, there is also a specialized class for sync/async downloads that
> supports authcfg: https://qgis.org/api/classQgsFileDownloader.html#details
>> I think we already discussed several times that it would be good to
>> incorporate this into a commons lib for QGIS. But if I'm correct the
>> actual interface was not exactly what some wanted, and if I recall
>> correct Nyall tried to pull this into c++ but hit some multithreading
>> issues.
>> But as Nyall says: I think this is a great lib to use in a plugin (also
>> because it used the QgisNetwork-stuff, so you can receive the signals
>> from it or log the precise urls, like we do in the QGISnetworklogger
>> plugin [1]
>> Regards,
>> [0]
>> https://github.com/planetfederal/lib-qgis-commons/blob/master/qgiscommons2/network/networkaccessmanager.py
>> [1] https://github.com/rduivenvoorde/qgisnetworklogger
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191126/c91052a6/attachment.html>
