[QGIS-Developer] [Qgis-user] Python Implementation of QgsNetworkContentFetcher
Denis Rouzaud denis.rouzaud at gmail.com
Tue Nov 26 21:26:26 PST 2019
Thanks Nyall for the precisions.
I wasn't aware of QgsBlockingNetworkRequest.
So basically, if I don't require authcf, then starting from 3.6 there is no
reason to use my python nam, I should use both
QgsNetworkContentFetcher and QgsBlockingNetworkRequest.
And from 3.10 if require authcfg in QgsNetworkContentFetcher.
Is this correct?
Cheers,
Denis
Le mer. 27 nov. 2019 à 00:27, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Wed, 27 Nov 2019 at 00:44, Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
> > Hi,
> > Jumping late but we use the work from NAM Alessandro did in a couple of
> locator filters.
> https://github.com/opengisch/qgis-swiss-locator/blob/master/swiss_locator/core/network_access_manager.py
> > I believe I have done very very few adaptations/fixes to the original
> work and it works like a charm.
> Not quite. It works in some circumstances, but it uses an event loop.
> So if you run it on the main thread, you're potentially doing an
> effective call to QApplication.processEvents, which can lead to all
> sorts of crashes. That said, it's generally a safe approach to use for
> QGIS <= 3.4... just don't use it in any code which relates to
> rendering!
> > I had in mind to bring this as is within QGIS core for some time. The
> main point being for us the blocking request rather than authcfg.
> That's EXACTLY what QgsBlockingNetworkRequest is -- please don't
> re-re-implement this!
> Nyall
> > Denis
> > Le mar. 26 nov. 2019 à 15:36, C Hamilton <adenaculture at gmail.com> a
> écrit :
> >> Thanks everyone. This gives me some good ideas. These are the possible
> solutions:
> >> 1. Write a python implementation of QgsNetworkContentFetcher or
> QgsBlockingNetworkRequest. With this I could look at the QGIS version and
> if it is 3.10 or greater import the core method; otherwise, import the
> python implementation.
> >> 2. Use the old Boundless implementation if it still works in QGIS 3.
> >> 3. Use QgsFileDownloader and save it as a temporary file before
> processing.
> >> Calvin
> >> On Tue, Nov 26, 2019 at 2:29 AM Alessandro Pasotti <apasotti at gmail.com>
> wrote:
> >>> On Tue, Nov 26, 2019 at 8:22 AM Richard Duivenvoorde <
> rdmailings at duif.net> wrote:
> >>>> On 26/11/2019 00.06, Nyall Dawson wrote:
> >>>> > There's not. But there's the ex-boundless "networkaccessmanager"
> >>>> > implementation that supports authcfg, which you can find at
> https://github.com/north-road/qgis-redistricting-plugin/blob/master/redistrict/linz/networkaccessmanager.py
> >>>> > (and other projects -- as far as I'm aware there's no real upstream
> >>>> > for this... Alessandro?).
> >>>> I used this Boundless thingie for several plugins now (original source
> >>>> is now pointing/redirecting to planetlabs [0]).
> >>> Yes, that's the "upstream" but I don't know if that one is maintained
> anymore.
> >>> Btw, there is also a specialized class for sync/async downloads that
> supports authcfg: https://qgis.org/api/classQgsFileDownloader.html#details
> >>>> I think we already discussed several times that it would be good to
> >>>> incorporate this into a commons lib for QGIS. But if I'm correct the
> >>>> actual interface was not exactly what some wanted, and if I recall
> >>>> correct Nyall tried to pull this into c++ but hit some multithreading
> >>>> issues.
> >>>> But as Nyall says: I think this is a great lib to use in a plugin
> (also
> >>>> because it used the QgisNetwork-stuff, so you can receive the signals
> >>>> from it or log the precise urls, like we do in the QGISnetworklogger
> >>>> plugin [1]
> >>>> Regards,
> >>>> [0]
> https://github.com/planetfederal/lib-qgis-commons/blob/master/qgiscommons2/network/networkaccessmanager.py
> >>>> [1] https://github.com/rduivenvoorde/qgisnetworklogger
> >>>> _______________________________________________
> >>>> Qgis-user mailing list
> >>>> Qgis-user at lists.osgeo.org
> >>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>> Alessandro Pasotti
> >>> w3:   www.itopen.it
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191127/c80b8d0c/attachment-0001.html>
More information about the QGIS-Developer mailing list
