[QGIS-Developer] [Qgis-user] Handling a large number of raster layers with Qgis architectural limitations
Patrick Dunford
enzedrailmaps at gmail.com
Wed Nov 27 19:35:16 PST 2019
Hello,
the issue is not with the performance drawing the raster, it is with the
system only being able to have a certain number of file based rasters
loaded in a project before it will crash.
On 22/11/19 11:08 AM, Alexandre Neto wrote:
> AFAIK,
> WMST creates pyramids in cache as needed, hence it may do a better
> balance between disk usage and performance. You can control the number
> of pyramid layers you create and the compression format of it to save
> some space. But having raster files with 4000x4000 pixels with no
> pyramids will make a full read of the raster file to show even only a
> bit of it... That will make QGIS performance really poor.
> Thereºs this blog post from 2010 that does some comparison
> between several formats and their sizes and performances. It's in
> portuguese, but I think you can find ways of translating it.
> https://blog.viasig.com/2010/01/mosaicos-de-imagens-em-mapserver-com-gdal/
> Hope it helps
> Alexandre Neto
> On Thu, Nov 21, 2019 at 2:05 PM Patrick Dunford
> <enzedrailmaps at gmail.com <mailto:enzedrailmaps at gmail.com>> wrote:
> Building pyramids gobbles up heaps of disk space. I tried pyramids
> on 157 MB layer, which created an extra file 1.6 GiB.
> I can't see the WMTS building lots of temporary file pyramids
> using up disk
> On 18/11/19 10:50 PM, Alexandre Neto wrote:
>> Hi Patrick,
>> Sorry for asking, did you create pyramids (overlays) for your
>> raster "tiles"?
>> See more information about pyramids on QGIS official documentation:
>> https://docs.qgis.org/3.4/en/docs/user_manual/working_with_raster/raster_properties.html#pyramids-properties
>> To create pyramids on many files, it's probably better to use
>> GDAL directly to process all files in a folder:
>> https://gdal.org/programs/gdaladdo.html
>> My feeling is that the WMS service is doing that for you, and
>> that's the reason why it works well with a service.
>> Alexandre Neto
>> QGIS Support
>> www.qcooperative.net <http://www.qcooperative.net>
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191128/ac83e6b0/attachment.html>
