[QGIS-Developer] masks tooltip in Layer Properties
Andreas Neumann a.neumann at carto.net
Thu Nov 28 06:02:00 PST 2019
Hi Richard,
I can answer your first question:
It is about selective masking of symbol levels behind labels and point
symbols, in order to create nicer map labels and symbols. You can mask
darker symbol levels behind a label or symbol, but retain lighther
symbol levels (like a lake, forest, etc.) without getting these ugly
white halos behind the labels.
See also https://oslandia.com/en/offre-qgis/selective-masking/
and https://github.com/qgis/QGIS/pull/30747
There seems to be a bug with the tooltips - yes.
Greetings,
Andreas
On 2019-11-28 14:40, Richard Duivenvoorde wrote:
> Using the Layer properties dialog (in master), I spotted an item
> 'Masks'. Could not find any description or clue in the stuff shown.
> But I saw that the tooltip of it shows (see screenie):
> "If the remove duplicate nodes options is activated, duplicate vertices
> will automatically be removed from geometries which are edited on this
> layer".
> Found a documentation item:
> https://github.com/qgis/QGIS-Documentation/issues/4368
> first question would be: what is it, but second question: is the tooltip
> the right one? Is it a copy/paste thingie? Or is it just not (yet)
> telling what this tab is for :-)
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191128/876d8bb4/attachment.html>
More information about the QGIS-Developer mailing list
