[QGIS-Developer] LTR management [was Re: Delaying 3.10.1?]
Jürgen E. Fischer
jef at norbit.de
Thu Nov 28 07:25:06 PST 2019
Hi Even,
On Thu, 28. Nov 2019 at 15:48:42 +0100, Even Rouault wrote:
> > I've been "playing" with appveyor (doesn't work - hits the 1h timeout),
> > azure-pipelines (which kind of works) and github workflows (which does not
> > yet work) to implement the Windows CI many people are keen on. Progress is
> > very slow - every single step takes ages… A successful run takes more
> > than 2-3h on azure-pipelines…
> Did you try to contact azure-pipeline support ? They might be receptive to a
> request to increase both the CPU count and disk space. Especially if you say
> that QGIS is a cool open source project where people can display... Bing Maps
You think? I didn't try that yet - but I apparently didn't yet fully grasp the
cache concept - I only perchance had a few hits - but the misses might well be,
because I meanwhile changed either the key or they weren't written in the first
place because the available space was already exceeded. A list of caches to
check would be nice…
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191128/25ad5ab9/attachment-0001.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191128/25ad5ab9/attachment-0001.ksh>
