[QGIS-Developer] Antwort: Re: delayed PR of 3.10.1
SSchmidt at gfi-gis.de SSchmidt at gfi-gis.de
Fri Nov 29 01:51:07 PST 2019
Hi Jürgen,
thank you a lot,
        Hi Susann,
        On Fri, 29. Nov 2019 at 09:36:13 +0100, SSchmidt at gfi-gis.de wrote:
        > So I decided to compile it with last version for downloading (
        > QGIS-Codeversion 6ffa89eb3e)
        > But how can I get the source code from github? I can't find a
branch for
        > this version.
        $ git branch --contains 6ffa89eb3e
        release-3_10
        or visit
--> this does the trick: https://github.com/qgis/QGIS/commit/6ffa89eb3e
I doesn't knew to git checkout 6ffa89eb3e
Before I tried release-3_10 and final-3_10 but then I get errors with heap
corruption :-o
see the mail from Nyall Dawson:
                On Thu, 14 Nov 2019 at 20:32, <SSchmidt at gfi-gis.de> wrote:
                > Hello,
                > in my plugin I set up a rasterlayer like this:
                > QgsRasterLayer* lyr = new QgsRasterLayer(src->Dir + "/"
+ src->File, firstTBLayer->Title, QStringLiteral("gdal"));
                > if (lyr->isValid())
                > QgsProject::instance()->addMapLayers(QList<QgsMapLayer
*>() << lyr, false);
                > QgsRasterRenderer* rend = new
QgsMultiBandColorRenderer(rLyr->dataProvider(), redBand, greenBand,
blueBand);
                > rLyr->setRenderer(rend);
                This looks fine. It's likely there's something else at
play, possibly
                a local build issue.
                Nyall
        which also shows (among a ton of backport branches) release-3_10.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel.
+49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
+49-4931-918175-50
Software Engineer           D-26506 Norden
https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on
FreeNode
[Anhang "signature.asc" gelöscht von Susann Schmidt/gfimbh] norBIT
Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Juergen Fischer, Nils Kutscher HR: Amtsgericht Aurich HRB 100827
Datenschutzerklaerung: https://www.norbit.de/83/
So I think my local build issue now is solved with code version 6ffa89eb3e
All looks fine.
Freundliche Grüße aus Leipzig
Susann Schmidt
Softwareentwicklung
GFI - Gesellschaft für Informationstechnologie mbH
Philipp-Rosenthal-Straße 9
D-04103 Leipzig
Geschäftsführer: Andreas Richter
Amtsgericht Leipzig HRB 12054
USt.-IdNr.: DE179049354     Steuer-Nr.: 231/109/06412
ESRI Solution Partner      und       ER Mapper Reseller
Tel. 0341 961 3310    Fax 0341 961 3311   Mail info at gfi-gis.de
Web  www.gfi-gis.de  und  www.themenbrowser.de
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191129/4f895db0/attachment.html>
More information about the QGIS-Developer mailing list
