[QGIS-Developer] QGIS aborted when opened (randomly)
matteo
matteo.ghetta at gmail.com
Tue Oct 1 23:54:37 PDT 2019
Hi devs,
I'm facing a very very very strange situation. I have 2 QGIS installed
(3.4 from package and master compiled on debian sid).
When I switch on my computer (I did not update nothing, no QGIS, no
recompiled QGIS no update on debian in the last 2 weeks), when I try to
open both QGIS I SOMETIMES get this error (calling qgis from package,
same error for master). And QGIS died.
If I try and retry, SOMETIMES I can open it. No other software are
opened. Any clue?
Thanks
Matteo
matteo at debian:~$ qgis
/usr/lib/python3/dist-packages/qgis/core/additions/qgsfunction.py:107:
DeprecationWarning: inspect.getargspec() is deprecated since Python 3.0,
use inspect.signature() or inspect.getfullargspec()
args = inspect.getargspec(function).args
/usr/lib/python3/dist-packages/qgis/utils.py:685: DeprecationWarning:
the imp module is deprecated in favour of importlib; see the module's
documentation for alternative uses
mod = _builtin_import(name, globals, locals, fromlist, level)
QGIS died on signal 11[New LWP 2996]
[New LWP 2997]
[New LWP 2998]
[New LWP 2999]
[New LWP 3000]
[New LWP 3002]
[New LWP 3004]
[New LWP 3005]
[New LWP 3140]
[New LWP 3141]
[New LWP 3144]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007fceb13d9640 in ?? () from
/usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
[Current thread is 1 (Thread 0x7fcea1cdce40 (LWP 2994))]
#0 0x00007fceb13d9640 in ?? () from
No symbol table info available.
#1 0x00007fceb13c4305 in ?? () from
#2 0x00007fceb13c4bfc in ?? () from
#3 0x00007fceb13c78fe in ?? () from
#4 0x00007fceb140bcfa in ?? () from
#5 0x00007fceb1443404 in ?? () from
#6 0x00007fceb14432c0 in ?? () from
#7 0x00007fceb1443550 in ?? () from
#8 0x00007fceb1472c17 in ?? () from
#9 0x00007fceb14764ce in ?? () from
#10 0x00007fceb13423d8 in QLayoutPrivate::doResize(QSize const&) () from
#11 0x00007fceb1343469 in QLayout::activate() () from
#12 0x00007fceb13264e6 in QApplicationPrivate::notify_helper(QObject*,
QEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#13 0x00007fceb132d9b0 in QApplication::notify(QObject*, QEvent*) ()
#14 0x00007fceb1dbfa0b in QgsApplication::notify(QObject*, QEvent*) ()
from /usr/lib/libqgis_core.so.3.4.12
#15 0x00007fceb09aa029 in QCoreApplication::notifyInternal2(QObject*,
QEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#16 0x00007fceb09ad00b in
QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*)
#17 0x00007fceb09fbda3 in ?? () from
#18 0x00007fcea9905ebd in g_main_context_dispatch () from
/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#19 0x00007fcea9906140 in ?? () from
#20 0x00007fcea99061cf in g_main_context_iteration () from
#21 0x00007fceb09fb454 in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#22 0x00007fcea0e77391 in ?? () from
/usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#23 0x00007fceb350285d in QgisApp::QgisApp(QSplashScreen*, bool, bool,
QString const&, QString const&, QWidget*, QFlags<Qt::WindowType>) ()
from /usr/lib/libqgis_app.so.3.4.12
#24 0x000055a001cb056f in ?? ()
#25 0x00007fceb03b3bbb in __libc_start_main (main=0x55a001cae3c0,
argc=2, argv=0x7ffee1f4e258, init=<optimized out>, fini=<optimized out>,
rtld_fini=<optimized out>, stack_end=0x7ffee1f4e248) at
../csu/libc-start.c:308
self = <optimized out>
result = <optimized out>
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {0,
-6572917756161359799, 94145713223232, 140732689343056, 0, 0,
-1119832396317523895, -1146960219580727223}, mask_was_saved = 0}}, priv
= {pad = {0x0, 0x0, 0x7ffee1f4e270, 0x7fceb3d9e190}, data = {prev = 0x0,
cleanup = 0x0, canceltype = -504044944}}}
not_first_call = <optimized out>
#26 0x000055a001cb366a in _start ()
[Inferior 1 (process 2994) detached]
gdb returned 0
Aborted
