[QGIS-Developer] pyqgis - canUninstallPlugin
Etienne Trimaille
etienne.trimaille at gmail.com
Mon Oct 14 00:25:20 PDT 2019
I'm adding back the QGIS dev mailing list.
Le lun. 14 oct. 2019 à 08:29, VOLPES-EXT, Jacky <
Jacky.VOLPES-EXT at canal-de-provence.com> a écrit :
> I didn’t share any code because I don’t know how to be more clear… :/
You said your code is not working and/or not called. So without seing it,
it was confusing ;-)
> The objective would be to prevent the plugin to be uninstalled in our
> specific company context :
> I want every user to have a specific set of plugins already installed in
> their QGis environment so they don’t have to manage installations or
> updates of plugins (thanks to the QGIS_PLUGINPATH environment var, where I
> will install and update the plugins for them).
> But as a result, if one user decides to uninstall a plugin, it will be
> uninstalled for every user.
Seems weird to change every plugin you are going to install for them by
adding this flag.
So you are using a network share for all installed plugins?
Why not a read only directory?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191014/7ba6ddfe/attachment.html>
